Material declaration report for M93C86-WMN6P
Our customer has requested a material declaration report for M93C86-WMN6P. We purchased 1,000 pcs from Avnet back in 2016. However, it appears that this part is now inactive, as I couldn’t find the part number listed under M93C86-W.
Could you kindly provide the material declaration report for M93C86-WMN6P? Additionally, could you advise if there are any alternate parts available? Would M93C86-WMN6TP be a suitable replacement?
M93C86-W | Product - STMicroelectronics
Thank you for your assistance.
Peter BENSCH
Peter BENSCHBest answer
The M93C86-WMN6P and the M93C86-WMN6TP are technically absolutely identical. The ordering number
  • without T stands for tube packaging,
  • with T stands for tape and reel
Since the material declaration refers to the actual device and not to the packaging, it is identical for both versions - you‘ll find it here.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
