Dec 15, 2023 11:14 PM UTC
Marking ID
I am trying to confirm the marking ID on the physical part (4FFT 8311) UFDFPN-8 EP for St. Micro # M24C64-FMC6TG
Dec 15, 2023 11:39 PM UTC
4FFT or 464T seem most prevalent for M24C64-FMC6TG. The number line is a lot/production code.
@Peter BENSCH
SJCUAuthor
Dec 15, 2023 11:45 PM UTC
Thanks for Reply!
Is there an App Note document available memory devices?
Dec 15, 2023 11:50 PM UTC
There are data-sheets, unfortunately a lot of ST's lack marking information.
I2C EEPROM's tend to have a pretty simple / common usage method.
Peter BENSCH
Dec 18, 2023 8:32 AM UTC
Correct, the current markings for the M24C64-FMC6TG are 4FFT (newer) or 464T (older, older, should no longer be available).
The last three digits of the 2nd row stand for the date code YWW, i.e. your 8311 is to be interpreted as 2013 or 2023, week 11.
Hope that helps?
/Peter
