Explorer
Dec 15, 2023 9:20 AM UTC
Marking from ST "293F305" 8 pins components
Could you help me to defined a 8 pins component from ST with marking 293F305 . Seem voltage limitation  (transils) ? Thanks Regards
Peter BENSCH
Peter BENSCHBest answer
Dec 15, 2023 11:50 AM UTC
Welcome @DM-Electron, to the community!
Ideally, you should include a photo of the device with such enquiries. However, I assume from your information that it is the LM293D, i.e. a dual voltage comparator.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
