fagundesbr
Jul 16, 2015 3:05 PM UTC
machine cycles - for instruction
Posted on July 16, 2015 at 17:05
hi there!
i´m using the Cosmic c compiler and STM8S microcontroller.
i can´t find this information:
how many machine cylces this function takes?
for(conta=0;conta<10;conta++);
it´s seem to me that the ''for'' takes 6 cycles in simulator, but i want to be sure about that.
sincerely;
    luca239955_stm1_st
    Jul 20, 2015 10:24 AM UTC
    Posted on July 20, 2015 at 12:24
    you have to split your problem in two parts:
    1) see what assembler is generated for your C Code
    2) measure the cycles for the assembler
    If you have measured 6 cycles for a for loop of 10 iterations either your measure is wrong or the loop was just optimized away.
    Hope it helps.
    Luca
