M95M02-DRMN6TP
M95M02-DRMN6TP
May I ask if there are any cases that cannot be   EEPROM programming   that can be shared?
We are unable to  EEPROM programming,
thank you
Peter BENSCH
You have asked the same question here.
  • What does the schematics look like?
  • What have you tried to programme the EEPROM (show us your programme)?
  • What works and what doesn't?
/Peter
LINZIBINAuthor
What are the general reasons why programming is not possible?
Do you have any cases where this product cannot be programmed? thank you.
Peter BENSCH
If someone actually has a problem when writing to an SPI EEPROM, this can usually be solved quickly. This is why I asked the above questions. If you can answer them, show us the schematics and what you have tried, someone might be able to help you.
