efstathioua
Feb 26, 2005 7:00 AM UTC
Locating absolute segment (program/constants) using the STVD7 3.0
Posted on February 26, 2005 at 08:00
efstathioua
Feb 25, 2005 7:28 PM UTC
Posted on February 25, 2005 at 20:28
Using the STVD7 3.xx we tried to locate an absolute segment at sector 1 of 72F521N9 with no success.
Using STVD7 2.54 this was done with the following command:
# locate .e4dTP1 at -b0xe000
+seg .e4dTP1 -b0xe000 -n .e4dTP -m4096
d:\sw\e4Gen\object\T4cons.o
How can I do that using STVD7 3.xx? Any syggestions anyone?
sjo
similar method, you need to overide the generated linker script via project settings/linker input and uncheck the auto checkbox.
modify script as you did in the older version.
sjo
