krishna2399
Oct 10, 2007 8:04 PM UTC
Linux 2.6 kernel porting for STR912FW44 based EVB
Posted on October 10, 2007 at 22:04
krishna2399
May 17, 2011 7:47 AM UTC
Posted on May 17, 2011 at 09:47
Hi Friends,
I would like to know the support for porting linux 2.6 kernel to STR912FW44 based EVB. If so, Please let me know what are points/steps need to care for.
Krishna M
mark9
give up now, because there is no MMU.
sjo
your choices are uclinux or ecos, as Krishna says your need a mmu for full linux.
sjo
krishna2399
Hi
I agree with you on the MMU required for Linux porting. But I came to know that the Linux 2.6 kernel can work without mmu hardware support. I would like to have clarification on this.
For 2.4 kernel MMU hardware support must.
Krishna M
mark9
Krishna,
You've probably seen
http://opensrc.sec.samsung.com/
which talks about the no-mmu port of Linu 2.6 to ARM. However, it doesn't look like it has any development on it for 2 years, and it only supports 1 samsung processor, so there is probably a lot of work to be done.
-Mark
