raunaque
Jan 3, 2005 12:20 PM UTC
linking error using HIware compiler
Posted on January 03, 2005 at 13:20
raunaque
raunaqueAuthor
Dec 30, 2004 10:57 AM UTC
Posted on December 30, 2004 at 11:57
Hi all
i am pasting the output i am getting while i am compiling the code . i am getting the error as follows
anybody to help me out
bye
WARNING L2300: Segment STACK_SEG not found in any objectfile
Reading initialization information ...
Allocating objects ...
ERROR L2009: Out of allocation space in segment BUFFER1_EP2_512 at address 1A50
ciccio2
Have you insert STACKTOP?
Example for ST7LITE 9, file project.prm:
* FILE project.prm
* ST7FLITE09
LINK project.abs
NAMES
main.o
isr.o
funcs.o
END
SECTIONS
MY_ZRAM = NO_INIT 0x0080 TO 0x00FE;
Le prime due locazioni di EEPROM contengono RCCR0 e RCCR1
MY_EEPROM = NO_INIT 0x1000 TO 0x107F;
L'area di ROM si limita a FFDC (seguono RCCR0, RCCR1 e i vettori)
MY_ROM = READ_ONLY 0xFA00 TO 0xFFDC;
PLACEMENT
DEFAULT_RAM, _ZEROPAGE, _OVERLAP INTO MY_ZRAM;
DEFAULT_ROM, ROM_VAR, STRINGS INTO MY_ROM;
NV_VAR INTO MY_EEPROM;
END
STACKTOP 0x1FF
INIT main
VECTOR ADDRESS 0xFFE0 DummyISR /* not used */
VECTOR ADDRESS 0xFFE2 DummyISR /* SPI */
VECTOR ADDRESS 0xFFE4 RTCISR /* LITE TIMER RTC1 */
VECTOR ADDRESS 0xFFE6 DummyISR /* LITE TIMER IC */
VECTOR ADDRESS 0xFFE8 DummyISR /* AT TIMER OVERFLOW */
VECTOR ADDRESS 0xFFEA DummyISR /* AT TIMER OC/IC */
VECTOR ADDRESS 0xFFEC DummyISR /* AVD */
VECTOR ADDRESS 0xFFEE DummyISR /* not used */
VECTOR ADDRESS 0xFFF0 RTC2ISR /* LITE TIMER RTC2 */
VECTOR ADDRESS 0xFFF2 DummyISR /* EI3 */
VECTOR ADDRESS 0xFFF4 DummyISR /* EI2 */
VECTOR ADDRESS 0xFFF6 DummyISR /* EI1 */
VECTOR ADDRESS 0xFFF8 DummyISR /* EI0 */
VECTOR ADDRESS 0xFFFA DummyISR /* AWU */
VECTOR ADDRESS 0xFFFC DummyISR /* TRAP, not maskable */
VECTOR ADDRESS 0xFFFE main /* RESET, not maskable */
