johnf
Feb 5, 2011 9:02 AM UTC
link?
Posted on February 05, 2011 at 10:02
Can you help me  - when I build example stm8l discoevry. dev  - linker returns error:
Running Linker
clnk -l''C:\Program Files\COSMIC\CXSTM8_32K\Lib''  -o Debug\discover.sm8 -fakeSemiAutoGen -mDebug\discover.map Debug\discover.lkf
clnk: unknown option -fakeSemiAutoGen
 The command: ''clnk -l''C:\Program Files\COSMIC\CXSTM8_32K\Lib''  -o Debug\discover.sm8 -fakeSemiAutoGen -mDebug\discover.map Debug\discover.lkf '' has failed, the returned value is: 1
exit code=1.
discover.elf - 2 error(s), 0 warning(s)
Where can be my problem?
Thamks,
fj
    Joan PRATS
    Mar 22, 2011 12:08 PM UTC
    Posted on March 22, 2011 at 13:08
    Hi John,
    I think this error is related to the license file from Cosmic. Do you have the license.lic file for the 32K free version?
    Regards,
    Joan
    stephane serre_O
    Mar 22, 2011 12:24 PM UTC
    Posted on March 22, 2011 at 13:24
    Hi John,
    In the STVD project settings, select your Cosmic license path (probably the 16K) by browsing the good root patch : C:\Program Files\COSMIC\CXSTM8_16K.
    The priginal project workspace has probably been saved with 32K license settingd.
    best regards
    johnf
    johnfAuthor
    Nov 26, 2011 5:12 PM UTC
    Posted on November 26, 2011 at 18:12
    Dear stefast,
    first - thanks for your answer!, but mypoblem is not solved.
    I have licensed both 16k+32k Cosmic. (when I do change to 16k, linker send the same error....
    Have you any other idea how solve my problem, please ?
    (I have not worked on STM8L some time, because there were many other projects... and now I can not start work  again...)
    Best regards,
    john
