omatza
Nov 14, 2005 10:17 AM UTC
lib2 for st7
Posted on November 14, 2005 at 11:17
lib2 for st7
omatza
omatzaAuthor
Nov 7, 2005 1:33 PM UTC
Posted on November 07, 2005 at 14:33
Hello
during my searching for documents I found, in my E:\Metrowerks\STM V2.0\lib\st7c_my_new\3rdparty\st7_lib2 a document called user manual.pdf.
In page 9 - main directory structure - I found that there is ST7lib_config.h file that contains some #defines to compile library called lib2, that deal with:
ADC, EEPROM, I2C, I2CSlave, IO, ITC, LART, LT, MCC, PWMART,SCI, SPI, TBU, TIMER, TIMER8, WDG, CAN.
I understand it is for all st7 family, with small changes between the different flavors.
Where can I get this library ASAP ????
Thanks a lot
Oren
info45
Nov 8, 2005 6:32 PM UTC
Posted on November 08, 2005 at 19:32
Hy,
try to download the ST7 library from STM directly.
These library are MW and Cosmic compliant and include many peripheral.
By
omatza
omatzaAuthor
Nov 9, 2005 5:23 AM UTC
Posted on November 09, 2005 at 06:23
Hi
I alreay tried to look there :-[
I can't find it.
do you have the link ?
(Am I the only one who thinks that st site is very hard to navigate, and that the search results are never what you need)
Oren
info45
Nov 9, 2005 2:19 PM UTC
Posted on November 09, 2005 at 15:19
Hy
try to download at this link.
http://mcu.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=15#Software%20-%20Microcontrollers
Search st library 2.1 ( about 5MB).
After download. install it; then You ca be see the User Manual to undestand how the library are composed.
Attention: the code is for an quickly start up but are'nt for all purpose.
In sereral case I have modified it because are GENERAL PURPOSE.
By
omatza
omatzaAuthor
:D
I found it.
I will install it later.
Thanks a lot!!!!
Oren
