September 7, 2023
LED turning red
What do you when your LD1 turns red everytime you plug-in a cable? The name of my board is nucleo-g071rb, I'm using cubeIDE. I am trying to do an STLink upgrade, but it says I'm not connected and should check my cable. LD3 and LD4 turn green, but LD1 turns red.
Issamos
IssamosBest answer
Hello @Lello1
No need for a code. Everytime you plug-in a cable in an stm32 nucleo board, the green LED LD3 lights up, LD1 blinks. So you can now if the cable is plugged in or not.
Best regards.
II
Issamos
IssamosBest answer
Hello @Lello1
Best regards.
II
