AMahe.2
March 29, 2023
Kindly fill the attached fo22 form.
Dear Team,
Hope you are doing good.
This mail is regarding to fill the declaration form for REACH,ROHS, BATTERY SUBSTANCE RESTRICTION, INDUSTRY RESTRICTED SUBSTANCE, OTHER LEGISLATION, PROP 65, CLP, BPR. Kindly declared the mentioned regulation in the attached F022 Rev AE form. Please do support us on this request. Since it's a high priority process, kindly declare the F022 form for the attached MPN .
Otherwise please provide FMD for the requested MPN.
I have also attached the sample document, since it's a priority process we need your support for declaring the F022 document.
If you are not the concerned person, please loop the responsible contact.
If you have any concerns let me know.
Billy OWEN
Hi @AMahe.2​
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
