4310239955_stm1
Jan 18, 2007 8:47 AM UTC
Keil vs Raisonance StartUp files
Posted on January 18, 2007 at 09:47
vincentchoplin9
May 17, 2011 7:35 AM UTC
Posted on May 17, 2011 at 09:35
I just re-read your post and saw you were asking about the docs...
You should find all the documentation you need there: (in RIDE)
''help''->''PDF''->''STRx tools''->...
Especially in these three documents:
Getting Started STRx
STR9x-lib manual
Compiler (GCC) manual
BR
Vincent
4310239955_stm1
Hi Vincent!
The bug was only that forgotten line :D
Now it runs all right :D
Thank you verrry much!
best regards!
Hanzz
vaclav2
Hi VincentC,
Thanks you for your advice!
I have BN746-ST7-ARM-80C51-P1-STR750 and ARM ToolChain 1.1.15.
I made all, but it has no effects.
I will attempt support from Raisonance.
Thanks and Best regards
Vendelin
P.S.
IS HERE ANYBODY, WHO WORKS IN THE RIDE IDE AND HAS CORRECT FUNCTION OF TIMERS and INTERRUPTS? :-?
[ This message was edited by: Vendelin on 18-01-2007 08:16 ]
vaclav2
Hi VincentC
All is all right!!!!!!!!!!!!!!!
Thaks you for yor help! :D
(I was blinking with wrong pin in the interrupt. :-] )
vincentchoplin9
Quote:
Then I will answer! ;)
Glad to hear it works.
BR
Vincent (Raisonance)
[ This message was edited by: VincentC on 18-01-2007 14:20 ]
