Jul 2, 2026 10:39 AM UTC
Junction Temperature of the below mentioned parts
Hi ST Team,
Can You pls share the Junction temperature of the following Parts.
LSM6DSVTR   M24M01E-FMN6TP
Peter BENSCH
Peter BENSCHBest answer
Jul 2, 2026 11:02 AM UTC
Both devices are designed for the temperature range -40...+85°C. The junction temperature is in the same range due to negligible self-heating, so it is not specified explicitly.
Does it answer your request?
/Peter
Peter BENSCH
/Peter
Jul 2, 2026 12:13 PM UTC
Hello Peter,
More information require regarding this parts, can  you help me for the thermal resistance values for the parts.
Thanks and Regards
Harsh
Peter BENSCH
Jul 2, 2026 5:43 PM UTC
As I mentioned before, the datasheet does not specify any thermal resistance values because of the low current consumption and, therefore, low power dissipation. However, you are welcome to create a personal ticket with the Online Support OLS and try to obtain further information.
Good luck!
/Peter
Jul 2, 2026 11:15 AM UTC
Hello Peter,
Thank you for the response, this resolve my query.
Thanks and Regards
Harsh.
