dhutchison1945
May 26, 2010 7:18 AM UTC
jump to a function instead of call her
Posted on May 26, 2010 at 09:18
    dhutchison1945
    May 17, 2011 1:08 PM UTC
    Posted on May 17, 2011 at 15:08
    Ciao EtaPhi,
    yes,I agree with you,but what if the sw_reset fails ? :)
    thanks for the replies :)
    bye bye
    Spectre
    fggnrc2
    Ciao Spectre.
    There is no difference between calling and jumping into a function (as long it's used for a software reset).
    The reason is obvious: that function will never return!
    EtaPhi
    fggnrc2
    If the sw reset fail, there is the watchdog ditch...
    Insert an infinite loop at the end of your function and wait watchdog reset.
    Thanks to the safety devices in STM8, this isn't either the last ditch.
    You can also insert an illegal opcode to force a sw reset.
    Ciao
    EtaPhi
