zheleznjakov
Jan 31, 2011 4:04 AM UTC
Issue the command BRES and register ITC->ISPR
Posted on January 31, 2011 at 05:04
why
reset command BRES
does not
work
one
bit of
the register ITC->ISPR
does not reset the
bit
in
the simulator
works
in
real
 mcu
does not work
However,
the command BSET
works
in
the simulator
and in
mcu
example (simulator STVD 4.2.0):
// ITC->ISPR6 &= ~(1UL << 6);
0x721D7F75      BRES  0x7f75,&sharp6 // before ITC->ISPR6=0xFF after ITC->ISPR6=0xBF
// ITC->ISPR6 &= ~((1UL << 6) | (1UL << 7));
0xC67F75        LD    A,0x7f75 // before ITC->ISPR6=0xBF
0xA43F          AND   A,&sharp0x3f
0xC77F75        LD    0x7f75,A // after ITC->ISPR6=0x3F
// ITC->ISPR6 |= (1UL << 6);
0x721C7F75      BSET  0x7f75,&sharp6 // before ITC->ISPR6=0x3F after ITC->ISPR6=0x7F
MCU STM8L151K6
example (real mcu):
0x721D7F75      BRES  0x7f75,&sharp6 // before ITC->ISPR6=0xFF after ITC->ISPR6=0xFF
0xC67F75        LD    A,0x7f75 // before ITC->ISPR6=0xFF
#stm8l151k6
    napoleoni.jacques
    Jan 31, 2011 9:27 AM UTC
    Posted on January 31, 2011 at 10:27
    It seems that by referring to STM8L15x reference manual, you're not allowed to write the 10 value in VECTxSPR[1:0] (priority level 0) that corresponds to the change of FFh value to BFh value (your comment ''before ITC->ISPR6=0xFF after ITC->ISPR6=0xBF'')
    In that case, ''the previous value is kept and the interrupt priority remains unchanged''. See Software priority register x (ITC_SPRX) description of Ref Manual.
    This feature is perhaps absent from simulator. This issue is then not linked to the behaviour of BRES command.
    Regards.
    zheleznjakov
    Jan 31, 2011 9:57 AM UTC
    Posted on January 31, 2011 at 10:57
    Thank you very much
    I
    have
    realized my mistake.
    P/S Sorry
    for
    my
    english :)
