hg-chen
Feb 14, 2007 6:33 AM UTC
Is it OK to put the pull up resistors on programming tool?
Posted on February 14, 2007 at 07:33
hg-chen
hg-chenAuthor
Feb 7, 2007 6:30 AM UTC
Posted on February 07, 2007 at 07:30
There are pull up resistors needed for JTAG related pins(like JTDI,JTMS,JTCK,JTRST),
Is it OK to put these pull up resistors outside of target board,
in the programming tool(board) connection of the related pins?
mehdi239955
Hi Kuni,
Find attached the optimal schematic for JTAG.
It would be better if the different pulls up resistors are inside the target board; however it should works normally if not. :-]
Best regards
MBS
________________
Attachments :
JTAG.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtJO&d=%2Fa%2F0X0000000aLS%2Fi_9w6qUPdFzhoUGjVY73ePmMCc15zK7qyEFBTmErHZI&asPdf=false
