alexbrown1986
Sep 19, 2007 3:24 PM UTC
Interupts (FIQ)
Posted on September 19, 2007 at 17:24
Interupts (FIQ)
amira1
May 17, 2011 7:46 AM UTC
Posted on May 17, 2011 at 09:46
Hi ab1986,
For enabling the interrupts, you should enable the VIC clock, enable the peripheral interrupt( MC_ITConfig : when using the STR91x stdlib), configure the ISR, the line, the mode and the priority for each interrupt (VIC_Config ) and enable the interrupt request line(VIC_ITCmd).
Please find attached an MC example using FIQ interrupt.
Best regards,
mirou.
alexbrown1986
Hi there,
I am new to the ARM core and am trying to create an interrupt from the CM0 module in the MC controller. I have set up the path and the masks correctly but cannot see how to enable global interupts.
Can anyone point me to documentation about this or explain how to enable / disable interupts.
sarao
Hey Mirou,
Thanks as always for your responses. I just wanted to clarify a couple things.
As I interpret your email, you state the following order for enabling interrupts:
1. Enable VIC clock
2. Enable Peripheral Interrupt
3. Configure the ISR, the line, the mode, and priority
4. Enable the Interrupt Request line
But, as I read the source code:
Code:
<BR>... <BR> MC_ITConfig(MC_IT_CM0, ENABLE); // Step 2 <BR> SCU_AHBPeriphClockConfig(__VIC,ENABLE); // Step 1 <BR>... <BR> VIC_Config(MC_ITLine,VIC_FIQ,0); // Step 3 <BR> VIC_ITCmd(MC_ITLine, ENABLE); // Step 4 <BR>
Q: Is the order of step 1 & 2 important?
Q: If so, which is correct order?
Again, thanks always for your support in these issues.
-Jeremy
[ This message was edited by: jsarao on 19-09-2007 20:55 ]
