y_gudekar
Jul 19, 2006 3:22 AM UTC
Interrupt disable for some insrtuction
Posted on July 19, 2006 at 05:22
y_gudekar
y_gudekarAuthor
Jul 18, 2006 1:49 PM UTC
Posted on July 18, 2006 at 15:49
I am using ST72561 chip in my application.
I am carrying subtraction operation on variable g_uch_number_of_unread_characters_pos_bos as follow.
g_uch_number_of_unread_characters_pos_bos--;
assembly code generated for above operation is as follow.
ld a,_g_uch_number_of_unread_characters_pos_bos
sub a,#1
ld _g_uch_number_of_unread_characters_pos_bos,a
I am incrementing same variable in intrrrupt.
while carrying 3 instruction for subtraction operation i want to disable interrupt (while executing 3 instruction, even if interrupt comes, then it should get invoke after executing 3 instruction).
whether following sequence will solve my problem?
SIM
RIM
If not, then what is other solution?
regards....
Yogesh
wolfgang2399
Hi Yogesh,
if you put the variable g_uch_number_... in the short addressing area (00..FFh) the compiler should generate the one instruction command:
dec _g_uch_number_of_unread_characters_pos_bos
WoRo
