kobi_hayun
Mar 29, 2005 1:09 AM UTC
Integrating the IAP FLASH drivers in the origin code.
Posted on March 29, 2005 at 03:09
kobi_hayun
Mar 27, 2005 9:59 AM UTC
Posted on March 27, 2005 at 11:59
Hi EveryBody
I am trying to integrate the IAP FLASH drivers (In ASM) in to my code.
I read the FLASH programming reference manual and I still don't understands How should I have to integrate the code? and how ST7 ''Knows'' that the FLASH is going to be reprogram?
HKobi
venkateswara
When you call the Flash programming routine, the ST7 will launch the corresponding operation (thru a internal NMI ) as a background task.
I suppose you are integrating the Flash programming code into other assembly code. It is similar to adding a extra .asm file to your workspace.
I suppose this helps.
