August 27, 2024
Integrating STSAFE-A110 with ESP32 for MQTT TLS authentication
Hai,
   I'm planning to integrate STSAFE-A110 with esp32 for MQTT TLS Authentication.
I downloaded the "en.x-cube-safea1". In that I saw that "\Authentication" example.
How can I integrate with my project? My setup is like cloud will running MQTT broker. ESP32 is a client.
My expectation was connecting ESP32 to cloud MQTT broker with the help of STSAFE-A110.
Which example I have to look?
Best Regards
Bose
Benjamin BARATTEBest answer
Hi @bose,
The integration of the STSAFE-A shall be done in your TLS stack, if you are using MbedTLS, you can have a look to this thread. You will find C code example for using the STSAFE-A resources within TLS session.
Best Regards,
Benjamin
Hi @bose,
Best Regards,
Benjamin
