jjyeh1976
Oct 2, 2009 5:56 AM UTC
IIC bus problem
Posted on October 02, 2009 at 07:56
IIC bus problem
    jjyeh1976
    jjyeh1976Author
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    I use STM8S105K IIC bus with a slave on address 0x60, while sending address to the bus, the STM8 cannot detect the ack bit, I'd capture the signal of both SDA and SCL, it's obviously (see attachment) that the slave had send the ''ACK'' at the 9'th clock, what's wrong?
    mozra27
    I have one question concerning your application
    - What is the slave type? If you use the AARDVARK I2C module and 7bit addressing mode you should shift the own address by 1
    Example: I2C Own address (Master) = 0xA0 shifted by 1 on Aardvark module (Slave) = 0x50
    Please check this point
    Mozra
