chris7
Aug 30, 2004 3:35 AM UTC
IEEE754-compliant floating-point routines in asm
Posted on August 30, 2004 at 05:35
chris7
chris7Author
Aug 27, 2004 10:43 AM UTC
Posted on August 27, 2004 at 12:43
Does anyone know of a standard implementation of the IEEE754 floating point routines for the ST7 and would be willing to point me in the right direction?
Kindest regards,
Chris.
fggnrc
Aug 27, 2004 12:10 PM UTC
Posted on August 27, 2004 at 14:10
Chris,
the floating point routines are too heavy load for a simple microcontroller like the ST7!
Its hardware can only afford unsigned multiplication while unsigned division has to be done by a software routine.
If you need the basic floating point operations, try to encode your data in a fixed point representation and use integer operations to ''simulate'' the floating point ones.
Regards,
EtaPthi
luca239955_st
The Cosmic compiler/libraries provide this implementation, including the source code for all operations (mostly asm for the basic operations, mostly C for the complex ones).
Hope this helps.
Regards,
Luca (Cosmic)
