Identify 8-SOIC with marking MZ938 (more likely 0621 or O621)
I am trying to identify an ST IC with marking MZ938.  It is an 8-SOIC and it is used in a circuit which helps maintain charge on a 24V battery and is fed by a boost switching circuit.  It also has 0621 marked on it.  I assume that's the date code.
Peter BENSCH
Peter BENSCHBest answer
The marking is 062I (with uppercase i) = TL062ID.
/Peter
April 9, 2025
Please attach a large, clear and in-focus picture of the IC
The MZ938 is likely a production code.
https://community.st.com/t5/analog-and-audio/i-had-a-probleme-in-a-ic-st-mzsu938-if-anyone-can-help-me-with-a/td-p/160341
April 9, 2025
Probably STISO621 not sure if wide or narrow body
https://www.st.com/en/interfaces-and-transceivers/stiso621.html
peterptAuthor
I appreciate the suggestion.  I will trace it out and see if this makes sense.
