clanuchnik
Dec 8, 2004 7:39 AM UTC
ICT Mode
Posted on December 08, 2004 at 08:39
ICT Mode
clanuchnik
Dec 7, 2004 11:10 AM UTC
Posted on December 07, 2004 at 12:10
I enter the ICC mode
Then using the write memory command
I download a program that swiches I/O pins in RAM
Then I set the STACK to the starting address of my downloaded program in RAM
Then I sent the command Go
My downloaded program just set PORTA and PORTB as push pull outputs and then an infinite loop
.loop inc PADR
inc PBDR
jra loop
Should I see all the outputs changing after Go Command executed ?
Claudio
