vianney
Jul 23, 2003 8:56 AM UTC
ICAP with ST72F521R9T3
Posted on July 23, 2003 at 10:56
vianney
vianneyAuthor
Jul 22, 2003 9:15 AM UTC
Posted on July 22, 2003 at 11:15
Hi!!
I am using ST72F521R9T3 and I try to test input capture with St7 lib.
The program works as follow: I make a Analog to Digital conversion with a potentiometer, the result is displayed on leds on port D. I inject a signal (0-5V with a frequency of 10Hz) on Timer A ICAP1 pin (PF6) so as to see if the input capture is working...
When I inject the signal on PF6 the microcontroller crash!! The value displayed on the led doesn't change when I turn the potentiometer.
Here is my code.
Does someone see a mistake??
void main (void) {
PADDR = 0x00;
PAOR = 0x0F;
PCDDR = 0x00;
PCOR = 0x00;
PFDDR=0x9F; // Timer A ICAP1 & 2 as input
PFOR=0x00; // Floating inputs
PDDR = 0x00;
PDDDR = 0xFF;
PDOR = 0xFF;
PDDR=0xFF;
PDDR=0x00;
TIMERA_Init (TIMER_FCPU_
ITC_Init ();
EnableInterrupts; /* Clear I bit in CC reg */
TIMERA_IT_Enable(TIMER_ICAP_IT_ENABLE); /* Enable capture interrupt */
TIMERA_ICAP_Mode(TIMER_ICAP_1,TIMER_EDGE_1); /*Detect rising edge at ICAP1 pin*/
ADC_Enable();
ADC_Select_Channel(13);
for(;
while(ADC_Test_Conversn_Complete()!=1)
PDDR=ADC_Conversn_Read();
pragma CODE_SEG DEFAULT
pragma TRAP_PROC SAVE_REGS
void interrupt 8 TIMERA_IT_Routine(void)
unsigned int CAP2_Value; unsigned char i,Temp;
int i1=0;
int i2=0;
if(TACSR & 0x10)
/* if(TIMERA_Status_Flag(TIMER_FLAG_ICF1)==TRUE) Call to Check ICF2 */
Temp = TACSR; /* Clear ICF2 */
Temp = TAIC2LR;
/* TIMERA_Clear_Flag(TIMER_FLAG_ICF2); Call to clear ICF2 */
/* call to get capture value and also clear ICF2 */
CAP2_Value = TIMERA_ICAP_Getvalue(TIMER_ICAP_2);
for(i1=0;i1<=200;i1++){
PDDR=0x01;
for(i2=0;i2
PDDR=PDDR<
Thanks for answering.
Best regards.
Junior.
itsmejatinus
Jul 22, 2003 11:43 PM UTC
Posted on July 23, 2003 at 01:43
Try to first initilize the input capture registers and then enable all interrupts.
vianney
vianneyAuthor
Thank for your help, Ranjeet... but the problem persist.
First I thought it was a problem of interrupts management, because the program crashed only when i inject the 0-5V signal...
So I've decided to see if the microcontroller is able to detect the signal edge on the pin. So I've decided to disable interrupts, and I just check if the micrcontroller see a falling edge on PF6.
I've added a 10k pull-up resistor on PF6 (because PF6 is configured as floating input), and I inject a 0-5V signal on this pin.
I've changed my code as follows:
void TIMERA (void) ;
void main (void)
// Configures port D as output
PDDDR = 0xFF;
PDOR = 0xFF;
PDDR = 0x00;
// Configures PF6 as floating input
PFDDR = 0xBF;
PFOR = 0x00;
PFDR = 0x00;
TACR1=0x00; //detect a falling edge on PF6=ICAP1
TACR2=0x00;
ADC_Select_Channel (13) ;
ADC_Enable( ) ;
for( ; ; )
if(TACSR & 0x80==0x80){
TIMERA( ) ; //If the microcontroller detect a falling edge on PF6, then call TIMERA function
// Waits for the end of the conversion
while( ADC_Test_Conversn_Complete()== 0 )
// Reads the A/D value and writes it on the LEDs
PDDR = ADC_Conversn_Read( ) ;
#pragma CODE_SEG DEFAULT
// TIMERA Function
void TIMERA (void)
volatile unsigned char Temp;
int i2=0;
int i1=0;
Temp = TACSR;
Temp = TAIC1LR;
// Display a value on the leds, just to see if the program run to TIMERA function
for( i1=0;i1
PDDR=0x01;
for(i2=0;i2
PDDR=PDDR<
The Program never runs to the TIMERA function, I can't see anything on the leds
Can someone help me?
