netz
Feb 4, 2008 5:57 PM UTC
IAR EWARM 5.1
Posted on February 04, 2008 at 18:57
IAR EWARM 5.1
netz
netzAuthor
Feb 4, 2008 4:32 AM UTC
Posted on February 04, 2008 at 05:32
We have to update to IAR 5.1
Unfortunately, they have changed many things ( I think to
the worse).
Has anyone hints how to compile the STR71-API, especially
the assembler sources?
Thanks,
Steffen
tech9
Hi Steffen,
I haven't migrated yet, but I came across Technical Note 40394 on the IAR support site.
http://supp.iar.com/Support/?note=40394
Maybe you should have a look, as it explains the major changes, including on the assembler and linker. I think some assembly files need to be replaced with newer versions.
Also, if you are on the web site, there is a 28 page migration guide (pdf file) that could help you a lot:
ftp://ftp.iar.se/WWWfiles/arm/Guides/omarm_2.pdf
Hope this helps a little.
Regards,
Tech / Jp
