infoinfo964
Aug 16, 2010 8:13 AM UTC
IAR based project for STM8L and wake-up by AWU
Posted on August 16, 2010 at 10:13
    nanayakkaraan
    May 17, 2011 1:09 PM UTC
    Posted on May 17, 2011 at 15:09
    Hello AlexDion,
    Am also having a similar problem.  I want to set registers of STM8L152C6 as follows and that is the syntax I am using.
    But the registers are not get assigned.
    TIM4_PSCR = 0x0A;
     TIM4_CR1 = 0x01;
     TIM4_IER = 0x01;
    When debug values are not assign to registers.
    Have you got any idea on this issue?
    Any suggestions regarding this matter is appreciated.
    Thank you.
    napoleoni.jacques
    I suggest to use STM8L10x standard peripheral library available at
    http://www.st.com/mcu/familiesdocs-120.html
     that can be adapted for IAR and including AWU peripheral.
