prog2
Iap Program Method
  • October 16, 2003
  • 3 replies
  • 772 views
Posted on October 16, 2003 at 07:07
Iap Program Method
prog2
prog2Author
Posted on October 13, 2003 at 12:42
Dear All,
I use the st7lite09 microprocessor. I need to reprogram the uP in IAP mode but using ST routine the uP dont work in normal mode while it's correct in debug mode because in the debug mode the EEProm Program is unloked.
Why in normal mode the RASS Key dont unloked the EEProm?
jatin
October 13, 2003
Posted on October 13, 2003 at 13:58
Please refer ''ST7 Flash Programming Reference Manual'' downloadable from the same site.
[ This message was edited by: Jatin on 13-10-2003 17:29 ]
prog2
prog2Author
I'm reding ''ST7 Flash Programming Reference Manual'' and prove but I'dont know because the uP reprogram dont work
Help me, thank you
