saravan
Jan 30, 2005 6:16 AM UTC
IAP problem
Posted on January 30, 2005 at 07:16
IAP problem
saravan
saravanAuthor
Jan 30, 2005 3:39 AM UTC
Posted on January 30, 2005 at 04:39
I have a problem with IAP for ST72521.
I am using the IAP driver available from ST site.
I always get ''Operation Failed'' status flag from ECMD.
Initially through inDART i am setting option bytes as ''Disable read out protection''
I am using a External Chip Oscillator of 16 Mhz and my Fcpu is 8 Mhz.
I am following the below sequence with watchdog disabled:
RASS Disable (56 & AE as keys)
Sector Erase (sector 1)
Toggle a port pin if successful
Infinite loop
Could someone throw some light what could be the reason for this?
Thanks in Advance,
Sarav
saravan
saravanAuthor
Jan 30, 2005 6:09 AM UTC
Posted on January 30, 2005 at 07:09
I wanted to clarify a few points regarding my previous problem.
I have the probelm with Flash Erasing(sector 1) itself. St72521 is a HD flash device.
I have verified that my device is not damaged due to overcycling , by writing some test code into sector1.
I am attaching my Metrowerks project for reference. I have configured my device with option bytes ''7D B7'' through inDART.
I am using ST662A charge pump on my board.
saravan
saravanAuthor
Oops sorry couldnt attach properly!
Trying once again
________________
Attachments :
TRY_FLASH.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Eo&d=%2Fa%2F0X0000000bVu%2FzA4aRd_8ZnhMQvQWRHt0jYZj6KtauIEFNZDqQ_WZH9U&asPdf=false
