djrose
Feb 24, 2003 10:06 AM UTC
I2C slave configuration
Posted on February 24, 2003 at 11:06
djrose
djroseAuthor
May 17, 2011 9:53 AM UTC
Posted on May 17, 2011 at 11:53
Was about to give up on this - Then noticed the details of the P3SFS register.
Once I conditioned the port pins to be used for I2C I started to receive acknowledgements.
Silly me
djrose
djroseAuthor
Has anyone had any success with code to use the uPSD as an I2C SLAVE?
Whatever I try (and I've now tried a lot), I cannot get the uPSD to generate an acknowledge on receipt of a valid control (aka address) byte - Causing the master to indicate a failed transfer.
I found some example code on the ST web site, but this only included MASTER functionality.
