moshikome
Jun 8, 2003 1:57 PM UTC
I2C Master Receiver
Posted on June 08, 2003 at 15:57
I2C Master Receiver
moshikome
moshikomeAuthor
May 17, 2011 9:54 AM UTC
Posted on May 17, 2011 at 11:54
I have a very serious problem in operating the uPSD3200 I2C hardware as master receiver mode with AT24C512 (Atmel) standard I2C eeprom chip .
The write direction from the microcontroller to the eeprom seems to be o.k .
However,when i want to read data from the eeprom it doesn't work .
From some reason the eeprom doesn't send me the data and the SCL line is not changing .
In the uPSD master receiver algorithm ,it says in step 4 to write 0xFF to S2DAT .Why?
Who is responsible for the SCL line when reading from the eeprom ?
Is there perhaps a similar driver for the uPSD 3200 implementing eeprom write/read ?
Thanks.
