fabrice23
Jan 12, 2006 11:32 PM UTC
I2c-FRAM
Posted on January 13, 2006 at 00:32
I2c-FRAM
fabrice23
fabrice23Author
Jan 12, 2006 8:26 AM UTC
Posted on January 12, 2006 at 09:26
Hello everyone,
I have some troubles to do R/W on a I2c, FRAM.
I know that my post have been send on this subject but no answer solved my problem.
I am using a driver tested on an EEPROM at 100Khz and we just change it to a FRAM running at 400Khz. I use the V1.2 of I2c given by ST + I removed bug on ((FCLK/Clock)-9)/3;.. also I don't use the RCCU function and I forced FCLK = 48000000;
I am currently using a STR710Fz2H6BGA144 with a FM24CL16G.
Do you have any pointers ?
thank you,
pierre
[ This message was edited by: fmeunier on 13-01-2006 05:00 ]
fabrice23
fabrice23Author
ok
I found the problem. In I2C, I removed a wait at the end of the writting and even if the FRAM is quick, there is still a need for a wait...
pierre
