a3b
I2C BUS SPEED
  • February 23, 2004
  • 3 replies
  • 783 views
Posted on February 23, 2004 at 13:31
I2C BUS SPEED
a3b
a3bAuthor
Posted on May 17, 2011 at 11:58
Thank you for your answer.
sjo
You will have to comply with the minimum speed device, eg. 100KHz.
I2C devices are only upwardly compatible.
A possible solution is bridging - have a look at the latest I2C spec which mentions this.
sjo
[ This message was edited by: sjo on 23-02-2004 17:44 ]
a3b
a3bAuthor
On a particular design, I have componants with different Bitrate under i2C such as:
1 24C02 E2PROM at 400 KHz,
2 X UPSD up to 750 KHZ using 24 Mhz XTal,
1 DS1307 Clock at 100 Khz.
does anybody know this:
Can I use different bitrates : 750 Khz to communicate between UPSD, 400 KHz from upsd to E2PROM, 100 Khz from UPSD to Clock ?
Or am I obliged to run at minimum speed 100 KHz ?
