Abidwe
October 25, 2022
I would like to know the maximum output current for each channel on part number VN9D30Q100F.
We will be using this part to drive 6 automotive contactors. Supply voltage is 12/24V.
Peter BENSCH
Peter BENSCHBest answer
Welcome, @Abidwe​, to the community!
The maximum current is limited internally, depending on the application you can drive different currents. Details can be found in the data sheet, e.g. in tables 56 and 61.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
