Ksimp.1
I would like to get a datasheet for a ST Micro product, I have attached a photo of the device
Peter BENSCH
Peter BENSCHBest answer
It's an LD1085CD-TR in DPAK (TO252) which has been already discontinued.
There is still the LD1085D2TR in D2PAK (TO263), but due to the bigger package it is not a drop-in replacement.
Does this answer your question?
/Peter
Peter BENSCH
/Peter
Ksimp.1
Ksimp.1Author
Yes it does Peter, thank you very much
Keith
Peter BENSCH
Great!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
Thank you and regards
/Peter
Ksimp.1
Ksimp.1Author
Just one other question, the regulator comes in different voltages, do I have the LD1085CDT which is an adjustable voltage output?
July 16, 2022
These both look to be a fixed voltage, you should check the south pad is ground, or goes to ground via a resistor. The one on the top side, doesn't look to be a divider, and this likely a standard voltage supply rather than something novel.
This looks to have been worked over several times, are you sure there isn't something else amiss with the circuit. Perhaps sketch out a schematic as you can discern it.
