infoinfo967
Nov 6, 2010 10:34 PM UTC
I/O PORTS
Posted on November 06, 2010 at 23:34
Dear,
I need your help about...I'm programing by asm,
I need to use the outputs ports to control lcd numbers. i don't know how to do to prepair the port to do output port. I don't understand the port configuration and usage manual 14587 page 100
Is the adress 0x5000 the correct adress to take out the data port a?
 void main(void)
#asm
LD A,#2
 LD $0,A
 ld a,#4
 ld $2,a
 mov $3,$0
 ld a,#8
 ld $f,a
  ld a,#4
 ld $0x5000,a ''PORT A DATA OUTPUT REGISTRER''
 #endasm
    brazov22
    Nov 7, 2010 8:05 PM UTC
    Posted on November 07, 2010 at 21:05
    hi,
    before putting a data output on portA, you need to configure the port:
    LD A, #255
    LD $5002, A ;output push pull
    LD $5003, A ; see page 101
    brazov2
    infoinfo967
    Nov 10, 2010 7:19 PM UTC
    Posted on November 10, 2010 at 20:19
    Hi Brazov,
    Thank you I go to try it.
    Where are you from?
