Nickname15204_O
Feb 21, 2012 10:01 AM UTC
I have a question about the input voltage of ALTAIR04 IN eDesign
Posted on February 21, 2012 at 11:01
I want to design with ALTAIR04 in the software, but the input voltage must be less than 350V, I want to know that
 it means ALTAIR04 can’t be designed in a input of 440V AC?, or it’s only the limit of the software ?
Patrizia BELLITTO
Feb 21, 2012 10:48 AM UTC
Posted on February 21, 2012 at 11:48
Hi Peter,
first of all thanks for your interest in eDesignStudio.
Up to now, ALTAIR04-900 design on eDesignStudio supports input voltage lower than 350V, but we are working so that it can sustain ultra wide-range operations. You'll find this updating in next release.
Meanwhile, you can check application note AN3290 (http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/APPLICATION_NOTE/CD00286662.pdf), where, at page 29, it's described how to modify standard schematic, as that provided by eDS, so that it can sustain even greater input voltages.
Best regards,
eDesignStudio team member
Nickname15204_O
Feb 22, 2012 2:20 AM UTC
Posted on February 22, 2012 at 03:20
Hi Patrizia
thanks for your quick response.
I have seen the application note, expect the updated software
Best Regards
