boris2399
Oct 5, 2005 1:09 PM UTC
I can't emulate analog inputs on ST7MDT10-DVP3
Posted on October 05, 2005 at 15:09
boris2399
boris2399Author
Sep 30, 2005 4:45 AM UTC
Posted on September 30, 2005 at 06:45
I want to emulate ST7LITE15 device on ST7MDT10-DVP3 emulator but I am not able to get properly values from analog inputs. I have I/O pins and AD control register configurated as required (floating inputs, no interupts etc). I have connected trimmer potentiometers on these pins in the simplest way and I can read proper digital values (at min and max positions) but when I start A/D conversion I get only FF's as the results. I am doing something wrong or is there any hint that I don't take into account?
Many thanks in advance.
olivier239955
Can you please send us your init and ADC code in order to reproduce the problem by ourself.
Can you also provide me the start.log file which is in
C:\Program Files\STMicroelectronics\st7toolset\stvd7
to be sure that your emulator is up to date.
Withe best regards
