May 5, 2026 5:41 PM UTC
HW Version in ST33KTPM2I3WBZB1
In the TPM part ST33KTPM2I3WBZB1, what is the HW version that is supported? Is it ST33K1M5T revC or
ST33K1M5T revD?
Thanks.
Peter BENSCH
Peter BENSCHBest answer
May 8, 2026 2:29 PM UTC
If the information were not proprietary, it would have been in the document. But it is not there, which means it is proprietary. Sorry, my previous answer is still valid.
If you like, I warmly invite you to also ask the question in the non-public and personal Online Support OLS.
/Peter
Peter BENSCH
May 5, 2026 8:11 PM UTC
The data or information of all ST33 devices is strictly confidential and will only be handed over if an NDA is signed. For this reason, nobody in the public community will be able to help you, so you should contact your local ST contact.
Hope that helps?
/Peter
omniwizAuthor
May 5, 2026 8:27 PM UTC
Thanks for the response, @petr ! I am not sure that this information is proprietary as it is available here,
https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E41_PublicUse.pdf
The only ask from me is to confirm whether the HW version for ST33KTPM2I3WBZB1 is ST33K1M5T revC or ST33K1M5T revD.
Would you be able to provide the required information?
Best regards - O
Peter BENSCH
/Peter
