rkaya
Nov 27, 2018 5:45 PM UTC
HTTP POST & GET, under socket connection
I have configured One way authentication mode and able to connect to the server successfully.
After getting socket ID, I am using AT+SOCKW command to POST and GET.
e.g.
AT+SOCKW=00, 18<CR> (18 length is example)
POST /api/Frames HTTP/1.1<CR><LF>
DATA......
<CR><LF>
AT+SOCKW=00,18<CR>
GET /api/Contracts HTTP/1.1<CR><LF>
<CR><LF>
and in response always getting HTTP:400 Bad request error.
Please give a technical person contact number of ST employee, or please suggest solution on this.
    Elio Cometti
    Nov 27, 2018 6:00 PM UTC
    ​Hello,
    I think you are doing the right think but probably your request is incorrect.
    I mean, some headers (like Host, Content-Length in POST request) may be missing. Some fields are mandatory, others may be required by the web server and leading to a Bad Request reply if they are not sent by client.
    Regards,
    Elio
    rkaya
    rkayaAuthor
    Nov 27, 2018 6:16 PM UTC
    Thanks for your feedback.
    Could you please confirm, how to configure/send header contents ?
    How to send it?
    HOST:***.com
    Content_length: xx
    Data..............
    <CR><LF>
    is this correct way ?
    Can i use "HTTPPOST=url,path,data,443<CR> "
    to post data to https server?
    rkaya
    rkayaAuthor
    Nov 27, 2018 6:06 PM UTC
    How to send it?
    HOST:***.com
    Content_length: xx
    Data..............
    <CR><LF>
    Elio Cometti
    Nov 28, 2018 11:35 AM UTC
    your header seems correct (just need to add a <CR><LF> at end of every header lines).
    I suppose you are using SPWF01 for this, AT+S.HTTPPOST does only perform http requests and does not support https (that are based on TLS) requests.
    For a normative reference on HTTP 1.1, I kindly suggest to have a look to RFC2616 (and updates).
    You may also exercise with others application: for example if you have a Linux machine then you might try the following to get a valuable header:
    nc -l 12345 | xxd -g 1 &
    wget --post-data "This is a test POST message" -q http://localhost:12345
    You can also get this kind of info from developer tools of your browser.
    Regards,
    Elio
    rkaya
    rkayaAuthor
    Nov 28, 2018 3:23 PM UTC
    Hi Elio,
    After HTTP POST, getting HTTP 500 Internal server error.
    (\"Message\":\"An error has occured)
    Could you please suggest on this?
    I am able to test with POSTMAN application.
