vividmusic
Feb 3, 2004 9:28 AM UTC
How to write an unsigned char into the upper byte of an int???
Posted on February 03, 2004 at 10:28
vividmusic
Feb 2, 2004 1:12 AM UTC
Posted on February 02, 2004 at 02:12
Greeting people!!
this is probably easy but how do you do it in c?
- write an unsigned char (byte) into the top byte of an int (2 bytes)?
im using the cosmic compiler
i guess you could do
int = char;
int <<= 8;
is there a quicker way or is that it?
thanks for your time
chris
parveen
Feb 2, 2004 7:54 AM UTC
Posted on February 02, 2004 at 08:54
Try using unions
union
unsigned int MyInt;
unsigned char MyByte[2];
}A;
Hope this helps
Regards,
PraveenG
vividmusic
Feb 2, 2004 7:27 PM UTC
Posted on February 02, 2004 at 20:27
Thanks it good to learn something new
chris
luca239955_st
Using a shift will produce
int_var = char_var << 8;
ld x,_char_var
clr a
ld _int_var,x
ld _int_var+1,a
that is, will also clear the LSB of the int you are moving the char into.
Another possibility is to use pointers:
*(char *)&int_var = char_var;
ld a,_char_var
ld _int_var,a
this will leave the LSB unmodified.
Hope this helps.
Luca
