Explorer II
March 10, 2025
How to set the gain of the TDA7491 HV 30/31 pin GAIN 0/ GAIN pin?
How to set the gain of GAIN0/GAIN1 pins 30/31 of TDA7491HV?
Peter BENSCH
Peter BENSCHBest answer
Welcome @ouyang, to the community!
You can configure the two pins according to the desired closed-loop gain. According to the data sheet, table 7, you can choose between 20/26/30/32dB.
In the picture you have inserted, both pins are set to VDDS = H, which corresponds to an open-loop gain of 32dB.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
AScha.3
See ds , figure 22 :
Gain settings: 0+0 V -> 20dB , 3+3 V -> 32dB , etc.
