anshul
How to restore RC calibration values
  • July 14, 2004
  • 5 replies
  • 1069 views
Posted on July 14, 2004 at 04:37
anshul
anshulAuthor
Posted on July 12, 2004 at 14:19
I need to set the readout protection after programming and calibrating the RC. If I reprogram the device, reset the read-out protection. Then the whole memory including the calibration values (RCCR0 and RCCR1) are erased. How can we restore these values?
ldefend1
Posted on July 12, 2004 at 14:52
Which MCU are you using?
Which in-circuit programmer are you using?
anshul
anshulAuthor
Posted on July 13, 2004 at 09:01
I am using MDT10 EPB for programming.
The device is ST72FLite29
anshulgrover415
Posted on July 13, 2004 at 09:10
When you are programming the device using STVP7 1.9.2. Then the RCCR values will be restored by itself. The programming mode selected should be either “Socket� or “ICP OPT Disable�.
anshul
anshulAuthor
Thanks for the information
