senayati
Apr 21, 2010 11:34 PM UTC
How to reset MCU through SWIM and command line
Posted on April 22, 2010 at 01:34
    sramsauer9
    May 17, 2011 1:08 PM UTC
    Posted on May 17, 2011 at 15:08
    You can use gdb7.exe to restart mcu after programming.
    I use the following command line:
    gdb7.exe --quiet --command=restart_mcu.ini
    Content of restart_mcu.ini
    <-----------schnipp------------->
    # define emulator reset port and MCU
    define emulator-reset-port-mcu
    target gdi -dll swim\stm_swim.dll -stlink3 -port $arg0 -mcuname $arg1
    mcuname -set $arg1
    end
    # reset command and quit
    emulator-reset-port-mcu usb://usb stm8s105c6
    quit
    <-----------schnapp------------->
    You have to replace the mcu type (here stm8s105c6) to the one you are using.
    Regards,
    Stefan
    senayati
    senayatiAuthor
    Stefan,
    Thank you for your reply. The solution you offered worked fine and it is just what I wanted. Thanks again
    Regards,
    Sia Enayati
