How to reset Emulated EEPROM (in MCU Flash) when new code is uploaded?
Title edited to make clear that this is emulated EEPROM - in the MCU's Flash.
How to reset the EEPROM every time a new code is uploaded?
Is this possible?
Thank you very much.
urbito
Senior II
February 25, 2025
Hello Joker,
Just as an example:
You have to find the datasheet for your EEPROM chip and find the Erase Operation command, so in your microcontroller you can send it.
For example, you check in your eeprom for a value that must be FF, if it is not FF, you clean the EEPROM.
Hope it helps.
Greetings
JokerJokAuthor
Hi, thanks for the answer, will the operation be performed only when uploading new code, or every time the MCU is booted?
Andrew Neil
You have to write the code to do it - so it will happen whenever you code it to happen!
You need to give more details about your system.
Andrew Neil
@JokerJok wrote:
 the EEPROM
What EEPROM ?
Please see How to write your question to maximize your chances to find a solution
urbito
Senior II
February 25, 2025
It's up to you and how you make the code work.
My words refer to the hypothetical case where you write your own code to check the EEPROM every time the MCU boots.
Best regards.
JokerJokAuthor
my MCU is: stm32f030rct
These are the addresses I want to reset their contents every time I upload new code.
I have some BYTEs that I store in EEPROM, and I reload them every time I boot the system.
But while I'm uploading new code, I would be happy if it were possible to reset the EEPROM every time I write code.
Thanks!
February 25, 2025
Perhaps use __TIME__ preprocessor define, and mark as a tag in EEPROM. Check if is consistent, erase and re-tag when it's different.
