wdcai
Jul 19, 2004 10:14 PM UTC
How to read stable a/d converter value? Can any ST engineer give me some advice?thanks!
Posted on July 20, 2004 at 00:14
wdcai
wdcaiAuthor
May 17, 2011 10:02 AM UTC
Posted on May 17, 2011 at 12:02
hanan54
hi
You can''t get a stable A/D reading. There is a prblem in same version of uPSD.
wdcai
wdcaiAuthor
I have written am email about a/d problem to ST technical support,I am looking forward to his reply,thanks!
joseph2399
Please send your question to
mailto:apps.psd@st.com
. Provide information about the board you are using (DK3200 or your own), version # if DK3200, oscillator frequency, your settings, what voltage you are measuring, what reading you expect and what you are getting, and anything else that you think is relative.
Also provide the following information so we know a little more about you:
Name
Company Name
Phone Number
Location (City, State, Country)
Production uPSD part number (3233, 3234, etc.)
Application
Projected annual volume (units)
Production start date
Thanks,
uPSD Applications Engineering
wdcai
wdcaiAuthor
Rev C silicon is used iin my project, and OSC is 18.432Mhz, I modified the turbo_upsd.h provided by ST,But the accuracy is about +/- 20 LSB ,not +/-2 Lsb, in fact , I want to know why upsd33xx can't provide separate analog ground and Vcc, how to deal with ground pins in Upsd while layout. All ground pins can be connected with a ground plane and don't need think about analog and digital ground?
Thanks!
joseph2399
uPSD3334 Rev C silicon is now available and is errata free. Rev A has some accuracy issues when using the prescaler. If you limit the MCU clock to 16MHz and use an ADC prescaler divisor of ''1'', you should be able to achieve +-2 LSB, otherwise the accuracy will be around +-4 LSB.
Rev A silicon has date codes of 5A5010332, 5A5010338, 5A5010345. Please contact your local sales representative or distributor to obtain rev C samples.
If you have a DK3300 with rev A silicon, please send a request for an updated board with rev C silicon to
. Be sure to include:
Name
Company Name
Phone Number
Shipping Address
(Address, City, State, Country)
Production uPSD part number (3333, 3334, etc.)
Application
Thanks,
