andreasdoerre9
Oct 26, 2004 3:19 AM UTC
How to programm the internal flash on ST10F269-Controller?
Posted on October 26, 2004 at 05:19
andreasdoerre9
Oct 25, 2004 9:38 AM UTC
Posted on October 25, 2004 at 11:38
Are there some known problems by programming the internal flash of ST10F269-Controller? My Programm work like in application note AN1496 descripted but it don't work well. Are there some examples/good ideas?
- For me its possibel to erease the flash block like in applikation note
(AN1496 without the here included errors) described.
- For me its not possibel to programm the ereased flash block. If I
read after my erease- and programm routine there are only 0xff on
every memory place. That means, erease work, programm don't
work. (Before I erased memory, I programmed it by an external
porogramm)
[ This message was edited by: andreas73 on 12-11-2004 15:47 ]
[ This message was edited by: andreas73 on 12-11-2004 15:53 ]
najoua
Could you please tell me what is exactly your problem and what do you mean by ''it doesn't work well'' ?
Bye
