jackie2
Jun 2, 2005 2:50 AM UTC
How to program ST72F63BK6
Posted on June 02, 2005 at 04:50
jackie2
jackie2Author
May 31, 2005 2:57 AM UTC
Posted on May 31, 2005 at 04:57
It seems that ST7VP do not support progarmming ST72F63BK6. Is there any new version software ?
Tks
alain2399
May 31, 2005 9:45 AM UTC
Posted on May 31, 2005 at 11:45
The Engineering Programming Board ST7MDTU3-EPB is supported by STVP7 r1.9.4. With it you can program the ST72F63BK6 device.
[ This message was edited by: Alaini on 06-06-2005 10:17 ]
sjo
May 31, 2005 5:01 PM UTC
Posted on May 31, 2005 at 19:01
Or if you want to build a programmer try Flashbash - www.spen-soft.co.uk
sjo
jackie2
jackie2Author
Jun 1, 2005 1:53 AM UTC
Posted on June 01, 2005 at 03:53
The ST7MDTU3-EPB do support the socket, however, the ST7VP version 1.9.3. OCT 27,2004 only support to ST72F63BK4; Is there any new version S.W(ST7VP)?
Tks!
chander
Jun 2, 2005 1:26 AM UTC
Posted on June 02, 2005 at 03:26
Jackie,
The new version of STVP7 will support the ST72F63BK6 device. It will be released in 1 or 2 months.
However, if your software is less than 16 K, then you can program the device by selecting BK4. Pls make sure that the firmware lies in memory 0x8000 to 0xffff in this case.
Regards.
jackie2
jackie2Author
Get it! Tks!
