wolfgang239955_stm1_st
Feb 18, 2011 11:43 AM UTC
How to prevent linking unused functions (cosmic)
Posted on February 18, 2011 at 12:43
    luca239955_stm1_st
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    use the +split compiler option, see the user manual for the details.
    Regards,
    Luca
    spiovan9
    Compiler
    optimization  Conf. Debug
    (.S19 bytes)      Conf. Release
    (.S19 bytes)
    Disabe
    (-no)  10162      10166
    Minimize code size
    (+compact)  9276  9280
     Costomize
    (+compact +split)  6952  6956
    thank you for replying for I had the same trouble though.
    Under the Cosmic 32k version I made some benchmark on my application which involves many from ST standard libraries even though I use only few of the functions actually. The bytes saving is considerable with +split option.
    Why the release configuration takes little more than the debug one?
    Stefano
    luca239955_stm1_st
    probably because they are actually the same thing: in the past the debug configuation used to have no optimizations (-no), but since this changed I don't know what's the difference between the two.
    If you post the two command lines passed to the compiler we can compare.
